I own a 99 and have been having problems with the truck wanting to fire up. Some times i will go out and it will start up just fine, next time i try it will sit there and crank away. i replaced the lift pump about a 1 1/2 ago, and replaced the fuel filter the last time i changed the oil about 2 months ago. I have a fuel gauge mounted on top of my fuel filter housing and it is reading at idle 9 and under throttle 15+ it only reads up to 15. Im wondering if i should install new lift pump or can it be somthing else. i also have replaced the gas cap because i have heard of stupid problems caused by leaky ones. if anyone has any suggestions let me know.
99 quad cab 4x4,edge drag comp, 5", kn, stage 5 jammers. 118000 mi
