temperature gauge shows approximatly 150 degrees! have replaced thermastat & gaskets from cummins. changed jiggle check valve & hose,radiator cap & did pressure & leak test on radiator & flow system (also checked new radiator cap) did not change temperature sending unit but after warm up at running 20 miles checked temperature in radiator & was the same as gauge within a couple of degrees took new tstat out & checked for gasket slippage & tested tstat in hot water. (would be pretty hard to loose or misalign gasket on the 98 tstat housing) all parts from cummins. would appreciate any & all suggestions or help. thxs dansel (1998 12 valve)
1998 12 valve s/b q/c ddt trans lots of eng. mods
dyno 502hp 973 f/t sadly only 17/18 mpg i love it
