For about a year now I have had trouble with the engine surging when putting the truck into drive. I thought that this might be normal @ first, but recently the problem has gotten worse. Now on ocassion (when going from park or reverse into drive) it will kill the engine. I've watched the tachometer and it actually goes down about a hundred RPM's when putting the shifter into drive. I've checked the level of the trany fluid, had the truck scanned for fault codes, cleaned battery terminals. I have noticed that with the 3800 lb camper on, it will not do surge at all. Can't figure it out though. Any ideas?? Is this normal?? Thanks in advance.
Chris
Chris
