Engine/Transmission (1994 - 1998) Engine/transmission Problems?
I hope the troubles are simply dropping out of lockup or OD.
However, from your description, I'm thinking your TC lockup clutch is slipping. Nothing except a replacement will solve that problem.
mopower 03
I have a 933 MHz p3 in a mini desktop case built in under the back seat. This is also tired into the gps for map tracking. A flat panel where you see it. A wireless keyboard mouse combo. With a sprint cellular Internet card. Works real well. I get about 2-4 times faster than dial-up and it will work anywhere in the USA that I have sprint cell service. It cost me $20 extra a month extra with unlimited service.
Put a mystery switch in and then test it. If it still slips your TC is slipping and you need a new TC, if not and all is well after the mystery switch your TC was unlocking and your TPS may need adjusting.
Paul R. Haller
