OK. I have searched all of the posts, but still cannot seem to find a difinitive answer. Recently I installed a FASS DDRP. At the same time I changed the Fuel Filter (Natuarally resulting in a leaking drain valve).
Since the installation of the FASS, the fuel pressure has never been as expected; maximum 12# at idle, 5-7' under WOT, but shooting to 15-20# under WOT. I contacted FASS, and they told me to do a pump volume test, as they suggest there is a blockage in the line /pickup in tank. Have not done this yet.
1. What should the pump volume be in the 20 second run time?
Also, more disconcerting is that the pressure now drops to zero for a few seconds (at idle /no load), then raises slowly to 12-14#. The light to fill up just came on BTW. ( I ran it low in anticipation of dropping the tank, checking the screen and installing a filter between the tank and pump.
2. is 25 micron to fine for a pre-pump filter? It is a canister type, similar to a normal PH 8A in size.
3. WHAT THE HECK IS GOING ON???
I pulled the connection from the pump and the connectors in the harnes as well as at the PDC and put a bit of Dielectric grease on them... no change.
Pump does not sound too happy... loud 'whirring' sound... perhaps because the tank is low, but still... and help would be greatly appreciated... . Jonathan
