RDMueller
I've been experiencing an unusual problem with my truck and wonder if anyone else has seen this or has any ideas. After driving for a while (at least 15-20 miles) with the cruise control engaged, if you then pull off the highway and come to a stop the engine will experience a very erratic idle, jumping around between 850-1200 rpm. It will continue to do this until you shut down and restart, after which it will operate normally.
A few additional points:
- this only happens after driving with the cruise control on
- the cruise control itself works perfectly
- there are no codes
- there are no other problems with the truck
- it seems to be more pronounced in warmer weather
- the engine does not run rough, just an erratic idle
- if you depress the accelerator, you can get it to run at a steady higher rpm
The truck is a 2001. 5 with a 5 speed and is stock except for a Raptor 100 lift pump. It has 230K miles on it.
