Hey y'all,
Just got back from a week long vacation trip to the Rocky Mountains of north central Colorado.
I have my fuel pressure gauge plumbed off of my filter housing outlet banjo fitting (Geno's), it is mechanical all the way into the cab gauge.
Friday the 30th of July I went to my local Cummins dealer for a fuel filter (spare) and noticed that my fuel pressure gauge was giving me some real freaky readings. It would run at 13-14 lbs for a while and then it would drop, hard, down to about 10-11lbs and sit there for a bit and got back up abruptly.
During our trip it continued to do this no matter what the load or speed I was going. Some times when it was at the lower pressure I'd "gas" (diesel?) it to pass a vehicle and the pressure would go back up to the higher level. Levels now continue to be about 14 on the high side but have dropped to about 6-7 on the low side when it drops.
I changed the fuel filter out while at the cabin but no change to pressures.
It has continued to fluctuate and it is bugging the heck out of me. I also noticed that as we went higher in altitude, the overall fuel pressures dropped little by little.
Is there a bypass valve somewhere after the lift pump that might be opening and sticking open?
I also have been using a different additive, could this be part of it? Although the last FULL tank did not have any additive in it.
Thanks in advance!
Thanks in advance!
