B.G. Smith
When i start the engine, usually after sitting for some time,( a day or two) it will start then immediately die. I have got into the habit of bumping the starter first the starting and that has worked well most of the time. This morning I did the bump started then start and it died after three starts before it came alive. Temperature here has been in sixties and seventies. I checked the lift pump pressure, bump starter and it holds 10#. After the lift pump shuts off the pressure stays at 10# for maybe 20 second the drops to zero. Also holds 10# while running. Any thoughts? Thanks. bg
