Look down below the fan and you will see the vibration damper. Looks like a small flywheel on the front of the crankshaft. It has notches cut into it about 90 degrees apart. Look closely and you will see a little sensor positioned at about 11 'o' clock. (Just going from memory) That part has a wire coming out of it, easy to spot. It is adjustable for distance to the damper. Take something about the thickness of a business card or a thin piece of cardboard, place it under the sensor, loosen the sensor, push it against your cardboard and tighten it up again. It should work fine. That's how I adjusted mine after the KDP fix.
