Error Code P1693-Back to the dealer!
Oil Housing Plug
Door Seals on 2001!
Wiredawg
Fellow Rammers:
Welp, today I goosed my truck going thru an intersection and got an error code P1693. In my manual, it says:"a DTC detected in companion module" and another entry lists this code as:"DTC Detected in PCM/ECM or DTC detected in ECM. "
Anyone have a clue what this could be? #ad
Wiredawg
2000 4X4 SLT QC 8' bed; 6 spd, 3. 54 ; BD exhaust brake and 4" exhaust syst; TST PM2; Airlift Super Duty rear air bags; RS 9000 shocks; pyro/boost gauges in 2 gauge a-pillar mount; back preasure gauge mounted under dash; KN air filter; Brown's Welding brush/grill guard, rear bumper & headache rack; nerf bars and aluminum roll top rear cover, Warn front receiver and Hadley air horns, 20K Reese hitch,Mag-Hytec dif cover,Psycotty Air.
Wiredawg,
This question came up recently but I cannot locate the thread it was in. The 1693 error code meaning can be obtained by hooking it up at your local Dodge dealer (Back to the dealer as you say). I'm remember that the code is generic for many things, but the 'error code machine" at the shop can locate the problem. Mine has the same code showing after my oil pressure sensor gave out, dealer replaced it, but obviously didn't reset the codes. I plan on leaving mine alone until I REALLY NEED to see the dealer again. #ad
David
2001 Ram 3500 Quad 4x4, ETH/DEE
"REAL TRUCKS RATTLE!!"
[This message has been edited by David Wheeler (edited 03-26-2001). ]
Thanks for responding David. I started the truck two more times and the check engine light went out. I would cancel my appointment with the dealer tomorrow, but I've had a stumble problem that I've had two ECM reflashes done to fix and is still with me.
Gonna ask the dealer to dig deeper to find the stumble. It happened this last weekend while pulling my 5th wheel, and it was brief, but violent when it happened.
I'll post results when I get it back from the dealer
Thanks, Wiredawg
Wiredawg,
I'm sure the dealer will find your problem with the error code. The stumble you mentioned sounded familiar, so I did a little digging. Check out these posts and see if possibly they address your stumbling situation (the truck, not you #ad
https://www.turbodieselregister.com/ubb//Forum4/HTML/000655.html
https://www.turbodieselregister.com/ubb//Forum4/HTML/000179.html
https://www.turbodieselregister.com/ubb//Forum4/HTML/000892.html
https://www.turbodieselregister.com/ubb//Forum4/HTML/001006.html
Good luck!!
David
[This message has been edited by David Wheeler (edited 03-27-2001). ]
Thanks David:
Got a call today that a factory rep and the deisel mechanic are checking my truck. Hopefully, they are working on the problem and not focusing too much on my Psycotty, TST and BD exhaust brake. This makes the third time I'm in for the stumble problem
Fingers crossed, I'm anxious to see outcome tomorrow.
Wiredawg
The saga continues...
The service rep called me today and told me the error code they extracted was on my injection pump. Said they are gonna run the test flow chart and check fuel pressures. Look'n in my service manual now for the procedure.
Looks like I'll know something tomorrow. Again, I'll keep yall posted. Additionally, I'll e-mail folks who responded to this post to let them know I've posted results.
Fangers crossed #ad
Wiredawg
My 5 Star service rep called me and told me my injection pump checked put fine and to come by and get it. I ended up getting to the dealership late after the service rep and mechanic had gone home.
Tomorrow, I'm gonndrop back by and ask for a copy of the tests and test result they performed. Will post results tomorrow.
I'm gonna run it with the PM2 on to see if I get anymore stumble. If I do, I'm gonna disconnect and run without it to see what happens.
good to have her back!
Wiredawg
[This message has been edited by Wiredawg (edited 03-30-2001). ]
Wiredog,
My truck is exactly the same as yours,a 2000 4x4 QC 6spd long bed with DDII's a PM3,and starting in Febuary I got a stuble once in a great while. So far it only happened six times and never did it before Febuary. The first three times it did it was on the same tank of fuel,so I blamed it on the fuel. The next three times have been about two weeks apart each,and on different tanks/brands of fuel. It did it with the PM on (set at '0') and off,and it also did it while I had a pressure gauge hooked up,so I know it's not the lift pump. My injector pump is strong,so I'm blaming it on the ECM. No codes ever showed up whenever it did it.
-Mike
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Star silver,Automatic,3. 54,SLT,Michelin 265/75
Truck stumbled two more times. I disconnected TST PM2 and will see what happens. Will post results here.
Wiredawg
boy , thats a pretty ballsy move to take it in with the PM2 on board and having a factory rep look at it . i'd have to guess its related to the PM , but you never know .
Turn your ignition key to run then off twice, then to run and leave it in the run position, do not start the engine. Watch the odometer and record the numbers it shows.
It should show you PCM and ECM codes in the odometer. Post the numbers if any show up. 0237 indicates low voltage from the boost sensor, 0234 indicates high voltage from the boost sensor.
There is a TSB for miss/stumble for 2000 Ram Diesel, I believe it is 18-24-99. This miss was cause by the stock program in the ECM. If the miss is caused as a result of the PowerMax, then it is usally the result of a loose 12 volt connection, or loose MAP harness connection if it sets a check light. If it does not set a check light, then it is a loose connection at the injection pump.
