I ordered the Hydronic D4 a year ago and set about installing it about a month ago.
One of the members (name escapes me for the moment) did document the whole thing on tape (I think his address and ordering instructions for the tape where mentioned in one of the TDR issues. Just out to help fellow members this member will ship you a copy for the cost of the tape plus shipping!)
Here's what I've found during my, as yet unfinished, installation:
1) Even though you probably all know this…be sure to lay out the entire installation inside on the floor a couple of times until you are absolutely sure how you will set about things. Not because it's a technically challenging installation, but rather, because there are many different sources of information and instruction and it is very easy to get confused about what applies to your particular install. I received "supplemental" instructions for the 2001 Ram that I didn't notice for a while that require you tap the coolant hoses in a completely different fashion than the "main" instructions.
2) The Espar mounting bracket did not mount to the Ram frame the way the instructions said it should. I had to move a line and use different holes.
I did coat the entire surface of the bracket, the part that comes into contact with the truck frame, with a layer of silicone to isolate, as much as possible, the unit from engine vibrations. In hindsight, I would should have used an inner tube!
3) I also needed to grind a notch out of the bracket so it cleared a welded spot on the frame and mounted flush. Be sure there isn't any contact between the bracket and the drive shaft…eyeballing it is fine, but I recommend sliding something in between to make sure you have good clearance. I discovered after I drove for about a week, with just the bracket mounted, that it rubbed slightly.
4) I don't like tapping into wires with those scotchlock connectors. Unfortunately, if you order the remote, you will be forced to do this. There is a 12-pin connector that interfaces with the 7-day timer. The remote has four wires that need to connect to the 12-pin connector. I decided to remove the pins and connect the remote wires to the pins and then reinsert them. If you wish to do it this way, you will need a pin removal tool and some extra pins. Since this is not supplied with the other parts, you will need the following, the part number is p/n 206 00 204 (for the 1. 6mm removal tool) and p/n 206 00205 (for the 2. 8mm removal tool). No one I have talked too seems to know which one I need, or how to get these parts. My electrical knowledge is limited, so I took the thing into Radio Shack first... no one had any idea.
Espar was quick to supply me with the part numbers, but you need to contact a distributor to order the parts. I have been in touch with three distributors over the last two weeks…still haven't been able to order what I need yet.
Also, the wiring schematic, on page 12 of the instructions, was the only place I found that shows you what to do. Here, the directions are lacking. Why Espar didn't make the remote a part of the timer connection I will never understand.
5) If you have a 2001 truck, you will have to take the gas tank all the way off (or lift the bed). On this model, you need to take the sending unit off and "drill" the top to accept the Espar pick-up.
IMPORTANT - do not mess with the rollover valve. Once this valve is unseated…it will not go back in. You will be forced to drive a screw through it to hold it in place or replace the entire sending unit approx. $375. 00. There was a factory recall for the sending unit for 2000 or 1999 trucks…I'm not sure which, so you might want to check before you get started.
With my truck I noticed that the rollover valve wasn't properly seated to begin with. I took the sending unit in to my Dodge shop, they gave me a new rollover valve... didn't seat right. Since they will not warranty anything you remove from the truck yourself…I had to halt my installation, put everything back together and drive the truck to the dealership.
You would think that they would be happy to just give me the part and save the labor charge???
I started this installation on the 25th of November. Currently, the unit is mounted on the bracket, none of the cab wiring is completed and the heater is capped off. I ran the exhaust and air pipes. My kit was missing one of the reducers needed to tap into the OE coolant lines and I am having the same problem ordering this part as I am ordering the pin removal tools.
Biggest problem…
It's getting cold in CT!!!
Marc
