Engine/Transmission (1998.5 - 2002) ETH (6SPD) + 275's + Edge EZ + intake/exhaust RWHP ?
2nd Gen Non-Engine/Transmission Replacing front pads & ABS problems
Engine/Transmission (1998.5 - 2002) Putting a auto in a 01 H.O.
PatrickCampbell said:
Curious as to how much power I will make with this setup given I can put the power down with a good clutch. Thanks!
I've dyno'd twice with this setup and had two vastly different outcomes... The first time I dyno'd 339 hp (Sept 03) and the second was 288 hp (April 04) with the same setup.
Thanks guys for the replies. That is right about what I'd like to be making. What about torque? Does it make good sense to go with these mild injectors and a mild box... versus say, no box and medium injectors?
Patrick, since you have the ETH, you might consider the DD TT version of the EZ. It has a little less timing & some consider that better for the higher compression of the ETH. Mach 1. 5's are the delux way to go for milage & they run significanly stronger than the 275's
