Started up my eu2000i gen set today and it was surging like crazy in the ECO mode. Normal was running good. Found that it would run in the ECO mode with the choke about half on.
Removed the carburetor and cleaned the dickens out of it with carb/choke cleaner in the aerosol can several times then used hot water and dried it with air pressure. Put it back together and it worked like it did when it was new.
If anyone has to do this beware of the little spring about 3/8" long and about 1/8" in diameter. Actually took my other one apart to find out where the spring went.
Dean
Dean
