Originally posted by rbattelle
An interesting point about the disposal problem... one I had not considered until just now. Gary, what do you do with yours?
But I believe the "fatal flaw" in TP filters seems to be "channeling", which occurs if you don't use a tight-enough roll. The oil tends to form a few small passages through the TP, rather than soaking through the entire roll.
As for the fibers, I understand what you mean, redram, but it seems to me that as soon as the roll is wetted with oil, all those fibers will stick like glue in the TP. Any that do make it into solution will be picked up on the next pass through the full-flow filter.
