My truck will do something similar,, but only when I come off of a hard load (Not a no load 3,200RPM)
If I let the truck idle for say 30 seconds,, then run it hard through 2nd and 3rd and at 2,700RPM WOT I just let off, push in the clutch and hit the brakes the truck will fall well below idle, and sounds exactly like a ton of air in the lines,, the truck shakes back and forth and the tach bounces about 75-150 RPM +/- from idle.
I do have a normal idle speed though,, just 75-150 +/- from idle speed (not 450RPM)
Sounds like it's firing real good on 3 cylinders and real soft on the rest. Has a very sweet Lope,, Blap, blap, blap,blap, blap,,, just like a 12V with an insane GSK
I am thinking bigger than stock injectors are confusing the ECM, and Injection pump computer.
I know my truck has a small bump (lope) at idle all the time,, more when hot,, It actually moves the truck around a little, but it is more noticable in sound from the stacks.
Just my $. 02
Merrick Cummings Jr
