I remain unconvinced that the pusher pumps are the answer and have been following this thread with much interest. As of 4/11, 33% of the stock lift pumps have died before 50K miles and a total of 44% before 100K miles. Looking at the responses to the dual Carter pusher pump failure rate, responses have shown 8 people with no problems after installing the second pump and 3 people with pumps failing. That is 27% with an average of 16K miles on the dual setup. That is not too far from the 33% of the single pump failures. What will happen as they approach 50K miles? I know that in some cases the original factory lift pump died after the pusher pump was installed, but that indicates the added inlet pressure to the factory lift pump may not be helping. More data is needed before these statistics are valid but the trend does not look good.
I hope we can find a solution to this design flaw on the best engine put into a pick-up truck.
