wasn't sure if i should post this here or in the 911 section. recently purchased a 2004. 5 with the HO motor. It appears to be somking more than normal. smokes white at idle sometimes and under light accel in overdrive. it does pour pretty heavy under hard accel. I've read a lot about lift pump failure and if that is the case, I'm looking at the Fass system. Also, I installed a used edge juice with attitude and the engine sounded like it was pinging and boost would not go over 20 psi. i immediatly took the programmer off. Guages are in my future but I want the truck running "right" before I start modding it. Any and all help is appreaciated!
