I had the BD Exhaust Brake ON my last truck, and I thoroughly enjoyed it, and it only gave me a problem once, and that is when the valve that operates it got gummed up. (I did clean it after I discovered the problem) I also installed many of these units on other CTD trucks. I did not like the instructions that came with the units, but they did some correcting as time went by.
The truck I now have (03') has the "Jacobs" brake, and I like it very well. The Instructions that came with it were simply put, GREAT!! It does a very good job as well. AS most of you know, the 2nd Gen trucks had a Vacuum pump, as opposed to the 3rd Gen trucks, but I think the pump that Jacobs has come up with is a good one. As I remember when they were in the process of development of the 03' Gen trucks, they had problems in the pump area, so they had to delay the release of the brakes until they had a proven pump... ... ... ... ... and I hope they found one!
I installed the Jacobs on my 03' truck, and it was not a hard task at all, and believe it to be as good as any other brake out there. It is wired to the computer on the engine, so there are no switches, other than the one to turn the system on, then when the go peddle is released, the brake unit come on.
Wayne
amsoilman
