I'm working on an anti-theft that is wireless, totally contained under the hood, you choose which 4 wires to open or close (max 5 amps each unless you add a power relay to that line).
Things like Crank Position Sensor 5volt or ground, ECM communication lines, ECM grounds, PCM communication, PCM grounds, CanBus, VP44 communications, VP44 grounds, ( I see you have a P pump) anything that does not carry a lot of amperage, but is critical to the ECM.
Wireless range is about 750 feet (advertised, haven't proved that yet). You do have a keypad (not key fob) to take with you (I would say about 4" long, 2" wide, 1/2" thick). The security codes are very very high quality and are not easily reproducable in the same pattern (pattern constantly changes). The keypad has 4 sets of ON / OFF latching type signals.
You can also use it like a pre-oiler for the engine. Leave the lines disconnected, crank the engine for 10 seconds (or enough to get the oil pump moving oil into the journals) connect the lines, start the engine.
Obviously does not do anything for towing or stripping the truck where it stands.
Bob Weis
