Exhaust brake noise?
Marvel Mystery Oil?
Bump or Thump After Shutting Down
On the older trucks the exhaust brake "jake brake" was very loud. Most cities restricted there use. Is this a different type of brake than the one for our trucks? Are the ones on our trucks noisy?
Probubly dumb questions, but I have no experience with Jake Brakes.
2001. 5 Silver 2500QC LB,4x4,5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Snow Plow Group, Clearance lights, most options, no leather. EGT,Boost,Westin side bars, Linex spray liner,(more to come)NRA Life Member. .
As far as I know, our exhaust brakes are legal everywhere. Mine is not loud, but at idle, it makes a kind of hissing sound.
Jake Brake = ENGINE brake
Engine brakes are noisier, and much more complex, than exhaust brakes. My understanding of engine brakes is that when applied, valve timing is altered, turning the engine into a large air compressor.
Many towns ban the use of engine brakes. I don't know of any restriction on our exhaust brakes.
Thomas is right, we have jake brakes on our engines and the basic understanding i have of the system is that it shuts off valves causing higher engine pressure to slow down the engine itself... . and it is pretty loud
the exhaust brakes i have heard around here are not bad at all
2001 3/4 ton driftwood 24 valve HO 6 speed; straight piped, silencer ring out
BodyGuard front end replacement.
Jason
John the answers about an engine break causing the engine to act somewhat like a compressor is correct. It seems everyone in my family is involved in deisel. Dad a mechanic for years, brother and uncles was and still otr drivers. Much noiser than the exhaust brakes we use. The engine break works better but boy can it screw up an engine if not adjusted properly or gets out of adjustment. Hope this helps.
2001 RAM 3500 dually Quad Cab SLT, 4. 10 limited slip, HO 245 hp, 6-speed, dark garnet pearl coat, interior agate, All options except heated leather, added Betterbuilt brite diamond tool box, Linex spray-in bed liner, DeeZee brite diamond cab/bed running boards and TurboSaver (from Gino's) also Reese 5th wheel 15k hitch. No plans to bomb. This is my retirment vehicle currently pulling 21' 5er want to buy 30 to 35 for retirment.
