Exhaust Brake Switch Install Photo's...
Aux Fuel Tank Setup- Need Help
Discontinued Lund Bed Cover Question
Shifter Mounted...
Wiring Routed Through Shaft...
Another View Without Mounting Bracket...
Shaft Wiring Exit...
exhaust brake switch
are all the shift levers hollow?? down to the 94's, thats a slick way to run those wires.
marv.
I have one of those 2-speed axle switches from NAPA wired to the E-Brake. I like it but it makes so much noise vibrating around. I am trying to find something else to take it place.
Anyone have any good alternatives?
Something that is push pull like the 2-speed rear end switch?
thanks
thanks
I use a boat switch from Wal -Mart and home made bracket taped and covered with black RTV. works for me Cost less than 5$ not much less. LOL Ron Bissett in Metro Louisville KY:rolleyes:
thanks
That's exactly what Jacobs is using for their Exhaust Brake kit for the 2003s.
It clamps quite rigidly to the shift lever.
Why not check with a dealer and see if you can get just the switch?
Shifter switch
Some one told me that Cummins ( for e-brake) now has a shifter switch they install on other than 03's. Any one know???
