Maximum EGTs that our engines can tolerate are frequently discussed in these forums. I have been concerned about EGTs in my vintage Gen II truck because if I don't watch the pyrometer on a full-throttle climb it will peg the needle at 1600° under some conditions. The problem is reduced since I had the radiator fins pressure washed.
I read with sadness the recent thread here by our fellow TDR member who lost the engine in his '04 while pulling RVs for a living. He cited high EGTs and wondered if his symptoms were unique. Another owner of a similar truck reported similarly high EGTs.
A friend, who is close to a Cummins insider, told me recently that '04. 5 and '05 trucks typically produced EGTs in the 1375° to 1425° range depending on altitude during Cummins testing.
The Cummins insider reported that current Gen III engines were built to tolerate such temps and satisfactorily tested at those levels.
This information doesn't necessarily mean earlier engines can tolerate such high heat or that we can add injectors and boxes without risk but it does tell me that aluminum pistons don't necessarily melt or fail with EGTs above 1300°, at least not on Cummins 600 or 610 engines.
Harvey
Harvey
