The ATS is a great product that does work as advertised. I wouldn't bother with it unless you were doing a turbo upgrade of some kind but if you do, it's a must. Cylinders 4 & 5 are really congested in the stocker.
The install is pretty straight forward. There is a heater hose bracket in the back, on one of the bolts that will give you trouble. Some guys have said they pryed it out of the way. I cut mine, did the install, wiggled things around and decided not to weld it back up. No problems after 12k miles. Twins are next, I'll probably secure it somehow then. Best of luck.
-Scott
