Exhaust Mnaifolds
Htt 64/14
Preporator DYNO thread
I am currently looking at the idea of going to twins. However with the 12V exhasut manifold there is no way to clear the twins with the ford heater box sitting on the drivers side firewall. If I could position the top turbo in a diffrent location it might work. So what other types of manifolds are there out there. Does the 3rd gen manifold positon the turbo down under the manifold and closer to the block?? Will a 3rd gen or 2nd gen 24V manilfold fot a 12V head??
Thanks,
Chad
THere are many different variations of the manifold used in ag, industrial applications. THe manifolds used in most tractors put the turbo up over the valve covers, or even straight down..... You could go to a Cummins dealer and have them let you look through their records..... Good luck, Marc
