exhaust noise
Front Control Arm Bushings
Is there a trick to pre-turbo EGT probe?
hey guys i have a question
i recently installed a JRE exhaust and now when the truck is at idle the actual pipe has a low pitched humm (some kind of vibration) directly behind the cab... this may be normal i am not too sure... it's just that small unplaced noises drive me crazy #ad
anyway i appreciate any help you can give me
jason
2001 3/4 ton driftwood 24 valve HO 6 speed; silencer ring out, Glasstight cab high shell, Practical Solutions high idle kit, JRE 4" exhaust, Hadley Bullly Air Horns
Alpine CD player, Kenwood 750 watt amp, 2 10"
JL subwoofers custom truck box behind the seat. My Truck
Jason
The noise is commonly reffered to as "Drone"
happens with a lot of exhaust conversons. Check out http://www.epiflex.com for some solutions on fixing this problem. It can be done for less, but these guys sell the best.
Steve in Spokane,01 4x4 Auto Quad Cab SB, NRA Life Member, 99- H-D FLHRCI Coalbalt Blue,00 XR650R Power Upped, Former PSD owner
Do a search for DEAF IN SEATTLE by me back about 9 or 10 -00. Might work for you, it has for several.
Some trucks drone and some do not--- it's a pig in a poke whether a truck will or will not. Even some w/Banks stainless do it.
EDIT: The rpm and drone will change when further bombing increases power. Boxes and injector changes will greatly affect the frequency and rpm range of the drone.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING, MAGNA MIRRORS onboard.
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
[This message has been edited by JNutter (edited 05-09-2001). ]
I have the Jannetty kit, mine has a slight drone, but i got used to after a week. It will actually decrease a little over time as the exhaust is coated with carbon.
