Exhaust Temp Gauge faulty?
Cometic hg and cut head compatible
freak accident! Please pray!
My exhaust temp gauge has been working fine up to several weeks ago,now it only reads around 2 to 3 hundred degrees and then the needle just sort of flutters and won't read any higher temp's. Would that be the gauge that's bad or the probe?
Thanks,
Mike
I don't know what kind of gauge you have but my Autometer started doing that a while ago also. If I tapped the gauge it stopped but then would start again. I noticed that it only did it with the lights on. I read something on here about an inconsistant reading and it said the culprit was the power supply. I had mine coming off fuse #17 in the interior fuse panel which is a switched supply for the cluster. I removed that and pulled my power from a switched fuse panel I installed and now it is fine.
