Engine/Transmission (1994 - 1998) Exhuast wrap question
Exhaust wrap
Rory: I used the Summit wrap from E-Brake to first hanger. No changes in egt. The wife says it helps the drone. It's kinda hard to put on with it on the truck.
I used it
I put it on my CTD , as the 4" pipe was less then 1/2" from the firewall and the existing "heatshield-fireproofing was burnt.
I noticed no difference in EGT's, but had no problems with heat from the down pipe from the jac-brake to floorboard bend.
It seems to deflect heat as designed.
I did the same as Bug Out for the same reason. All is fine. I think it was mentioned at one time that is should increase spool up, at least in theory. If I remember correctly, LSFARM said is reduced the noise in the cab just a touch, but I may be mistaken about that.
Take care,
Ryan
Did mine from the turbo to the muffler. I removed the whole section to do it. Wrapped it with 2 layers of 2" stuff. Then sprayed it down with silver BBQ paint to sort of seal it.
It may have helped the noise a bit. Can't say it helped EGTs. Supposedly helped to improve exhaust evacuation from the system (i. e. efficiency -> performance). I did it mostly to reduce under hood heat, heat around the firewall, and noise.
-Jay
