Trip Display stopped working.
How can it be determined if it is a data failure or a display failure?
Originally posted by dresslered
At least that is what the instruments said!![]()
Actually, the engine wasn't even running! I stumbled across an instrument diagnostic routine that I had not heard of before on another bulletin board and thought that perhaps someone could find a use for it. Here's how it works: Hold down the trip odometer reset button with the ignition initially off. Then turn the ignition on while still holding down the button. When the odometer display shows chec, let go of the button. The instrument panel will then enter a diagnostic mode. It will check every segment of the LED in the odometer, cycle all the instrument panel lights, and then actually step up the tachometer and speedometer in increments until finally reaching 120 mph and 4000 rpms. Not quite sure what I just accomplished, but it works on my 2001 Ram and my wife's 1999 Durango. Next, I would like to figure out if I can play astroids on it.
