Engine/Transmission (1998.5 - 2002) EZ + 275's + StockAuto
2nd Gen Non-Engine/Transmission Clutch Master Cylinder, HELP!
Engine/Transmission (1998.5 - 2002) Straight piped and thanks
Anyone running this combination without any problems? Can you run this combination without any transmission mods if you do not tow heavy? Need feedback please.
I have the EZ and DD1's. With both, the transmission slips like crazy, Just running w/ the DD1's, no problem, and before I installed the injectors, I was just running the EZ, had to increase the line pressure a bit and had no problems.
This combo will make your truck feel pretty good,
but your stock transmission is hating it and will start slipping on command in a week or so.
Thats what happend to me!
--Justin
DDewois, you forgot something in your mathematical formula...
EZ+275's+Stock Auto = Burnt up Dodge Transmission
Do this math instead...
EZ+275's+ATS = Cummins Power to the ground
But dont take it from me cause when I get an EZ I'll be calculating
EZ+275's+stock clutch = Smoking Dodge Clutch :D
Your transmission will be toast without mods. My transmission was slipping with just the EZ. You can see by my sig how I remedied the situation. All is well now !!!
