I installed the Edge EZ on my 2003 3500 with 56,000 miles and the motor has a very loud knocking sound with it pluged in ,(like to much timing advance ) I called EZ and they said a little more noise is normal and told me to check for trouble codes to see if something else is wrong , Two codes came up P0236 and code P2509 . I found the first to be the boost sensor but can not find the other code ,Could the EZ cause the codes ? I would like to find the other code before I take it back to the dealer . Thanks for the help !!!!
Just found the other ECM/PCM power input signal intremittent,
What does this mean?
