EZ Boost elbow question
PE-Comp = Big Smiles
Clutch is starting to stink
Hello All,
Is it detrimental to completely block off waste gate line?? While changing fluids and filters and general tinkering yesterday, I put pinch off pliers on boost hose to see if there is a difference. I keep my EZ on setting 2, and was getting 26 lbs of boost that would drop to 24 steady at wot. With hose clamped off I get 30 dropping to about 29 steady at wot. Also a slight SOP difference. Do I have a weak wastegate that opens even with the boost elbow supplied by edge? What are your thoughts on fixing this??
Thanks for your inputs
Ron
The wastegate actuator is not a "on/off" kind of thing. It's more of a "slow-on" with increasing bypass as it opens. Pinching off the wastegate shouldn't be a problem if you keep an eye on the boost - the wastegate is simply there to prevent an overboost condition.
Exactly what IS an overboost for these trucks? With a gasser, overboosting is really bad - it leans out your mixture and makes the combustion temperatures considerably hotter. In a diesel, more boost cools the EGT (granted, it takes more fuel to MAKE more boost, hence "increasing" the EGT over stock). Are we just interested in keeping the turbo at/around it's best efficiency points? Why do they even PUT a wastegate on the trucks to begin with?
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger, Autometer Ultralite EGT and Boost gauges in 2-gauge pillar w/tweeter, DD Stage II injectors, boost module, and boost elbow. Yee haw!
http://www.rints.com/hammond for photos!
Sorry,
For some reason, signature didn't show in my first post. Hope this works.
Ron
1998. 5 2500 quad cab long bed 4X4 4. 10 LSD automatic, 285/75-16 coopers, add on cab clearance lights, tailgate running lamps, Navigator backup lamps, MSC fog lamps, Banks PYRO,trans temp,boost guages on Apillar, Autometer fuelpressure guage on floor, DTT Convertor and VB, Magtec transmission pan, Psychotty Air, BD 4" turbo to tail exhaust, Edge EZ box, RS9000 shocks, Amsoil motor and diff fluids
