SnoKing
I am on a RV trip in the Western States and I am trying to understand the workings of the wastegate and boost adjustments. I had my PDR35-12W set to 30-32 lbs at sea level at home and now I am in the Colorado high country and seeing only 26 lbs of boost. Alt 6000-9000. I have turned the setscrew in all the way on the boost elbow, thus blocking almost all the boost pressure to the wastegate. Note, if I turn the screw out, the boost goes down!
The way I understand it, is the the spring in the actuator holds the wastegate shut and boost moves the actuator over coming the spring and opening the wastegate to regulate boost level. I tried to shorten the rod on the wastegate, but it is frozen up, so I put a couple washers between the actuator and bracket, which moved the actuator away from the wastegate arm (same as shortening rod). No Change. When I had the actuator off the wastegate arm, the arm moved freely.
I cleaned the IAT last night and this morning I checked and tightened all the boot clamps and check all the hoses. Near the fender wells also. No holes that I can see. I have more throttle in 3rd pulling hard at 19K with the 5er in tow, then I can cool at 26 lbs, so I do not think it is a fueling issue.
I want to clean the map sensor. I read 1 1/16 inch deep socket? Or is it really 27 mm?
When I get setup again in Taos, NM later today, I may pull the boost elbow and install a plug and test with wastegate out of the picture.
SNOKING
SNOKING
