EZ POWER!!!
Most boost out of EZ?
Sick auto fixed!
Installed edge EZ... well worth the bucks with first test drive and no trailer. My truck woke up! I have a question. . boost with EZ is 20#,did not install wastegate elbow yet. What are the effects after install and is it worth it?
2001 2500quad4X4SB auto KN Black Leather loaded Boost and EGT gauges EZ ordered
22lbs for me so far--but I think the ol' lift pump isn't so hot-dang thang drops to 2 psi at WOT--idles at 9-13 and is all over the board most other times unless I'm steady with the pedal then 9-13 psi again and sometimes the red light flashes--so in goes the Holley shortly and then we'll see if I get a little more boost--
chris sutton
1999 2500 24v qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & front ARB,
5" skyjacker lift w/ 35" BFG MT's on 16. 5x9. 75 Weld rims, black smittybilt step bars, black 3 pc. bug persuader,
black lumber rack, camel leather int. w/ mb quartz spkrs and JL Audio twin 10"sub stealth box under rear seat , PE EZ, DTT vb & tc, mag hy-tec transmission pan,
red magview diff covers front & back, SPA pyro/boost&fuel pres/oil temp on "A" pillar & coming soon: big injectors, HX 40 massaged, red L&L ladder bars, turbo temp monitor ,
4" Jardine exhaust, Holley fuel pump, upgraded fuel lines and PE box tweaked--the above is a big fat lie I really own a totally stock RAM
csutton , i assume you will be replacing lines also ? adding the holley and leaving the banjo arrangement will gain you little . if you haven't bought the pump yet remove your fuel lines , the banjo fitting is the restriction , pop off the lines and drill the holes in the fittings larger , be careful and do it in steps the fitting is brass , USE LOTS OF OIL , i don't have the final number but i think you will end up around or larger than 5/16 , not the 3/8ths that the line is .
[This message has been edited by Mopar-muscle (edited 03-09-2001). ]
I don't think the boost elbow will work with your truck. You have the HY35 turbo which is hardlined. See this link for a simple way to disable your wastegate:
https://www.turbodieselregister.com/ubb//Forum4/HTML/004461.html
I'm seeing about 28 psi max with this setup and EZ.
Steve
2001 2500 SLT QC LWB 4x4, AT, 3. 54 anti-spin, tow package, camper special, snow plow prep, travel group, SRW, RKE, fog lights, bright white / agate
A-pillar mounted VDO Vision EGT/transmission temp/boost guages, Mopar Performance transmission pan, EZ, Westin nerfs, Alpine tunes, silencer ring?, Reese Titan V hitch, Cody GN hitch, 20+5 14k gooseneck trailer
Great Lakes TDR
So the EZ elbow only disables wastgate on the ETH and not the ETC?
2001 2500quad4X4SB auto KN Black Leather loaded Boost and EGT gauges EDGE EZ
I'm not sure about the 5 speeds, but on the autos, there is a hardline connection between the compressor and the wastegate actuator head. If you have a flexible line between the actuator and the compressor, you can use the boost elbow.
Steve
Mopar Muscle--thanks--got the upgraded lines and pump installed last night & she fired up after 4 ignition ons & 2 short crank sessions--pressure holding steady at 10-11 psi-but need to take her out for a test drive--wife taking relative to airport right now so I got the kids---chris
Mopar or Chris, Can you give me a rundown of what you did to your fuel lines? I am at that point (see sig and add HX40 and 4").
Thanks
Brant
01 Excab 4x4 Driftwood, agate interior, Potect grilleguard, DeeZee FX black, Weatherguard crossbox, Montezuma tool box, Honda air compressor, fold down g/n hitch.
Geno's pillar mount combo guage, deactivated wastegate, custom exhaust, 5"
chrom tip, PE EZ, Hot PE box, DDIIs, Dunrite TC, Transgo shift kit, and K&N air filter.
Performance Diesel Dealer
