EZ Question
fin comb ,it works
EGT Probe, Drilling Exhaust Manifold
Kent Kuykendall
Does anyone know what the cut in is for fuel on the three settings on the EZ? I Know that on the DD Fuel Module (made by edge),setting one is timing only, setting two is fuel after 20psi. boost, and setting 3 is fuel after 2psi. boost. How does this compare with a regular EZ?
<font color=blue>Regular EZ is :
20 lbs boost
15 lbs boost
10 lbs boost
I believe the numbers on the DD EZ you quoted are not accurate to my knowledge, where did you get the info? Yes 1st setting is timing only, but II and III are similar to full EZ.
<font size=-2>
[This message has been edited by KatDiesel (edited 02-03-2001). ]
