The 1. 5's and the EZ will make an excellent combo! Even with my 2's I have yet to see egt's over 1,200 degrees (I haven't pulled yet, though). The EDMs added a bunch of power across the rpm range, improved the mileage, and added a cool romp-romp-romp idle when I'm maneuvering in first and reverse. Good stuff!
With just the EZ and my old LP I could pull the fuel pressure down to 5psi or less. With the new LP, the Wildcat Max Flow kit, the injectors, and the EZ I can pull the FP down to the high 9's. I went with the Max Flow kit mainly to keep the factory filter and lift pump, since they're pretty well available anywhere in the country if something goes wrong. That, and it will handle all the fuel I'll need for the mods I'm planning. The price was right, too.
And yeah, the clutch won't be hanging in there very long with the EDM's and the EZ. My best fuel mileage this winter was when I was babying my stock slipping clutch before I could get the OFE installed. Nothing worse than having the toys and not being able to play with them!
