Boost
My truck would make 21-22# boost before I added the box/elbow. I don't remember exactly what it would do on level 1 (same as EZ), but I'm sure it was close to 30#. I do remember that it would make 40+ on level 5--which is too much.
You'll make more boost with a heavier load on the engine. So use a hill or heavy trailer for testing.
Wastegate. Unhook the elbow and blow compressed air into the actuator. Regulate the air and see when the gate opens. I wouldn't apply more than 30-40 psi to the actuator--that much shouldn't be necessary. This won't clean it, but will let you see it function.
And clean/test or replace the IAT sensor. You can "view" what it is doing with an OBDII deal.
Back to the original question--you should have a PUFF of smoke, if you punch it with little or no boost. After 10#, it should clear out.
