Found on road dead! Not the engine but while I was on the highway I heard a loud clunk and then no 5th gear. 4th worked to get me over to the side of the road. Didn't check other gears. Looked underneath and my transfer case was cracked wide open with the guts hanging out! Towed it to dodge and they said needs a transfer case. Well I figured that but what doesn't make sense is they said fixing the transfer case will fix not having 5th gear in the transmission. This doesn't make sense but I'm not an expert. I've heard of the 5th gear nut problem on this transmission but supposedly it wouldn't cause any damage. I've lots of damage! Is dodge correct? Could I have a dual problem? Thanks in advance for your input.
Kevin
Kevin
