F1 hellfire???s, Silverbullet 66??s
Free wheeling mod
Fass
Ok here is the story... 2003 HO six speed dropped #1cylinder valve seat. Just keep in mind I do tow maybe once a month around 15,000lbs... I have tst/bddl stack, II stage 3 cp3, light port and polish head, Helix 2 cam with springs.
Are F1 hellfire injectors tow worthy with II stage 3 cp3?
Will the silverbullet 66 with surge mod from II be able to tow, remember I have a manual??
Or should I go with a 62 silverbullet??
I need some info asap I will be buying the cam, springs,turbo, and injectors today... . Wesley
Which Hellfires The 150 Plus Or The 200 Plus, I Dont Think The Stage 3 Cp-3 Will Support The Larger Hellfires With All The Box... , The 66 Will Work With The Mod If You Dont Lug The Engine, Dont Be Scared To Rev It, Your Already Not Going To Be Getting The Greatest Of Fuel Mileage And You Want Your Boost To Keep Your Egt Down And To Prevent Another Seat From Dropping, The 62 Is Probably A Way Better Towing Turbo But With All That Fuel Im Sure You Play Hard And Need The 66... Just Make It Twins And Forget About Surging And Towing Egt...
I just got off the phone with Brett at II and he said that the silverbullet on his truck pulling 14,000lbs is great. . he recommends the silver 66 without the surge mod... . I plan on twin turbos and cp3s in the future I already spent tooo much money on the head work, cam, springs, injectors, and stage 3 cp3... I Definately like to play hard. . I was thinking of going with the 150hp injectors??
I talked to my mechanic today and he told me that he thinks the 150hp hellfires from Dom M will bee to much with a silverbullet 66... Does anyone have this combo that will chime in?????
the silver bullet will be plenty of turbo for those injectors. we are running some decently large injectors in our shop truck with the silver bullet and are not having any issues at all with egt's. ours is an automatic.
