Found this on another forum but this was from a 2015 post so take the date into consideration.
From Chrysler Tech Authority:
"The air suspension system is an open system. The air suspension reservoir stores a specified volume of pressurized air for use when the system need to raise or lower the vehicle height. If an individual pressurized component of the air suspension system is damaged and air pressure is lost, the reservoir will hold any pressure left in the component. A scan tool is used to evacuate the component. After repair or replacement of the component, a scan tool can be used to refill the component from the reservoir.
The compressor cannot refill the reservoir and complete system if all pressure is exhausted, as in a compressor assembly or valve block replacement. The system will need to be filled at the reservoir with nitrogen. For complete filling of the air suspension system after a repair (Refer to 17 - Rear Suspension/Standard Procedure) ."
"The Air Suspension Unit (ASU) is made up of two primary components, the compressor and the valve block. There is a single pressurized air line between the compressor and the valve block to maintain system pressure. Control of the air compressor and valve block is from the Air Suspension Control Module (ASCM). Diagnose the air suspension system using a scan tool.
Air Compressor The compressor runs to maintain air pressure any time the vehicle height is being changed or in the event of a small reduction in over all system pressure. Integrated reversing valves in the air compressor allow pressurized air to be moved in two directions, making this a closed system. There is a desiccant located inside the compressor for moisture protection, and an air suspension hose assembly attached to the air compressor (including a filter) which are not pressurized, and can be replaced as an assembly. If water is visible in the filter, the air suspension hose assembly and the valve block must be replaced. An air suspension temperature sensor is attached to the air compressor bracket to monitor ambient air temperature for protection of the compressor."
