SPA has no tubing, it is possible to have a leak at the fitting, but not enough to get you down to 7 PSI. The truck would be a miserable gutless pig at that boost max. Do you have access to a digital camera? I have been following this from the 911 post this morning and am not sure you are in the right port. You should be getting 18-20, the peak recall feature on the SPA (the ushbutton) should show 20-21 PSI. You should be able to sustain 18 PSI through the gears. Something is not right. Is there any more info you can give to help us help you?
