Template errors
  • Template :: [E_USER_WARNING] Method canViewRmsItems is not callable on the given object (SV\AdvancedBbCodesPack\XF\Entity\User) (src/XF/Template/Templater.php:1277)
Factory pigtail with Jordan 2020
Here we go...wife has spoken
Anyone have the 98 gallon Transfer Flow Tank?
Wierd, looks like the power coming from the factory Dodge towing pigtail (2006) is constant and not ignition? Is this correct? When I wired up the Jordan it was on all the time even with the key off which is not correct, any ideas on this?
Factory Brake wiring pigtail 2006 Dodge
Ground: Dark green with black trace
Brake Lights: Light blue with white trace
Trailer Tow Elec brake feed: Light blue
Battery Feed: White wire with red trace
Jordan 2020 brake controller
Ground: White wire
Battery: Red wire
Brakes: Blue wire
Sounds correct to me. If the Jordan display is on all the time, then you need to loosen the cable a bit to keep it from activating with no pedal pressure.
I had that problem when I installed mine, you want the cable to be as tight as possible, but not to the point to where it is on all of the time. Good luck!
Thanks guys, that's exactly what it was, works great now. :D
