Loren
My engine fan clutch seems to have failed. From the research I’ve done here it looks like this is a common problem and the repair is to replace the fan clutch itself.
My truck is a 2016, 3500 single-rear-wheel, with the HO engine and an Aisin transmission.
First: How likely is it that my problem is somewhere else? I’m ASSUMING that it’s the clutch, but what are the chances it’s not?
Second: What is involved in changing the fan clutch?
It looks like there are four nuts on studs that hold the fan shroud in place, but it also looks like removing those nuts won’t allow me to actually remove the shroud. There doesn’t appear to be any way to get it out without removing the radiator. I must be missing something, right? (I hope.)
It looks like this would be a simple job if I could get access to the front of the fan. Is it just bolted to the four studs that stick out from the clutch? If so, it would be easy if I could just get to those nuts, but the fan shroud prevents that.
My understanding is that the fan clutch nut has left-hand threads. Right? (I’m hoping that I get this far.)
I just can’t imagine that Ram built this truck so that I have to remove the radiator to change the fan clutch. Some of you must have done this job before. I would really appreciate some pointers.
Thanks.
– Loren
Thanks.
– Loren
