Fan Clutch removal
injection pump timing
Brake Pedal bump.
Did any of you guys have trouble with the nut on the clutch being VERY tight?
I'm holding pulley with an 18" Pipe wrench.
Have a K&D clutch nut wrench with a torque wrench as additional leverage.
I'm turning Right/Clockwise to loosen it. It should be a left handed thread.
Can't budge it. Tried giving the wrench a few hits with a rubber mallet to break it loose.
When I was pulling with everything I had, I heard the torque wrench click. I was curious to what I had the wrench set at..... 120 ft lbs!
Dodge dealer replaced the clutch in 1996.
Service manual says torque should be 42 ft. lbs.
Any suggestions?
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 12-29-2000). ]
Bill,mine was a bear also. I had to have someone hold the pipe wrench while I hit my 1"drive breaker bar with a 4 lb dead blow hammer,got it on the first whack. I'll use antiseize when I replace it. Another case where what seemed like a 5 minute job turned into an hour.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
Thanks illflem,
I was begining to worry. I read threads where guys pulled the fan for the winter. Nothing was ever mentioned about any difficulty removing the **** thing. #ad
Ordered a Vice Grip Chain Wrench to hold the pulley with. Can you believe I looked in Sears, Home Dummies, Lowes and 4 local hardware stores and nobody carries them?
Bill, the place to find the more oddball vicegrips is at a larger welding supply. I bought mine at place called Ox-Arc,they're all over the west,not sure about on your side of the country. The chain type will work great for what you're doing,I use mine mostly for clamping odd shapes together for welding. Granger has them also.
While you're waiting if you have a heat gun,try that on it,I've had excellent results.
[This message has been edited by illflem (edited 12-29-2000). ]
When I put my horton on, I took a large BRASS punch/drift pin and turned the fan for the flattest spot and gave it a couple of whacks. Loosened it right up. Go with brass as to not damage the nut by taking a couple hits.
At A. W. D. we use an air chisel with a long, blunt tipped drift in the chuck and two or three short burps and it's spinning off on its own. The trick is short, sharp tapping with anything hard, like a dead blow hammer or a steel hammer.
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission.
I got my Vice Grip Chain Wrench at a True Value hardware store. Another place to look would be a bearing and industrial supply. I bought a real bruiser chain wrench made by OTC there that I have used with a long pipe to remove gland nuts from hydraulic cylinders. The thing I really want to know is which way do the threads go on clutch? I know some of the Phords have/had left hand threads. Are ours RH or LH thread?
2001. 5 2500 4X4 SLT, ETH/DEE, Amsoil Bypass Filtration, Mag-Hytec w/Amsoil, Walker 21468, Passenger Side Grab Handle That DC No Longer Installs as of 7-00, Michael Brolin CB Mount, 10K@122200
Hemi=D
Be careful using a chain wrench or vice grips on the pulley. It would not take mutch to bend that pulley. I made a special tool to hold the hub. I looks like a large "C" washer with a long handle attached. It has holes spaced to match the bolt heads that hold the pully to the hub. When you put the handle up against something solid, you can remove the fan without damageing anything.
If everything else fails you can borrow it.
And yes the threads are "left hand".
CPFF
CUMMINS POWERED FAST FORD
Another thing I'd try would be the new strap wrenches from Sears. I got my dad some for CHRISTmas but havn't been able to "test" them yet #ad
Take a long drift punch or steel rod put on the hex of the nut and give it a solid blow,you will want a tip about 1/2 inch. - 3/4 better. do a couple sides. Iuse a large pair of channel pliers/some times called water pump pliers. mine are from snap -on- and opened all the way fit across the diam. of the pulley. Another trick is to put a long pipe over your ratchet handle for more pulling power.
If you have a helper ,while your are pulling on the wrench have some smack the one onthe nut a soild blow withe a hammer.
Got it!
I just needed to give the clutch nut a few hits with a 3lb hammer and a long drift. It loosened right up. #ad
While in Sears I found a Universal Pulley Holder/Fan clutch tool kit. It came with 2 long wrenches. The smaller one fit the fan nut. Also includes pulley holder. A long sissors type bar that holds onto the heads of the pulley hub nuts. Decent tool. Good quality package.
Its K & D Part # 3472. Regular price $39. 99. Clearence price $20. 00. I was reading a Horton installation article in the TDR where the author spend $52 for just the wrench.
Thanks for the tips guys. #ad
[This message has been edited by HEMI®Dart (edited 01-01-2001). ]
