illflem and drawson, can you help?
Questions for you fanless (and electric fan) guys.
How do you deal with the a/c pressures? My Horton fan cycles even in cool weather due the a/c compressor running in all heater/defrost positions (other then vent on '98 and newer CTD's). I added an electric fan wired to run with the a/c clutch but the fan is low on cfm due to limited space between the condensor and grille. With R 134 freon, the compressor head pressure skyrockets without airflow across the condensor. The Horton rarely engages from radiator temps, even when towing at interstate speeds in the summer. I manually engage the Horton in traffic or idling to keep a/c pressure down and because I dislike the cycling of the Horton. I do enjoy the lack of fan noise and improved throttle response after removing the OEM fan
Second question, what brand and type of intake air temperature guage do you recommend? My aviation guage didn't survive the CTD. I've been testing ram air intake systems and found that intake temps increase at lower speeds (fanless and otherwise)and consequently, low boost smoke increases. A larger aftercooler would be a plus when we are truly BOMBed!!!?
