wscott--The info your getting from Mad Bomber is on a 2nd gen truck and does not apply to your truck. You do not have a VP44 pump. You have a high pressure common rail fuel system. From your questions I assume you didn't know this. You should by pass your stock fuel filter, but you will use the stock electrical connection. The hose provided with the FASS kit goes from the fuel tank to the FASS pump then to the high pressure pump. The most pressure you will have in the hose is 15 to 20 psi. The hose is good for 300psi. TDragna
