2nd Gen Non-Engine/Transmission FASS DDRP better than stock pump?
i was about to buy a fass DDRP when i did a search here and read that some guys are not getting any beter performance than the stock pump! they were getiing good pressure at idle, but when reving the pressure weren`t good at all! Any commens before i buy? i`ll be putiing the ddrp on my 01 automatic(engine near stock) has" banks power elbo "with 4" exhast and the "banks high ram intake. "
I've installed several DDRPs. One worked perfectly. The other 2 have been plagued with issues. I personally don't think they deliver the additional flow claimed. Also, the fuel pressure seems to vary greatly from day to day and pump to pump.
I think BD makes a better stock replacement pump. I cannot find my book, but thought there was something from Genos Garage.
I have had good luck with my FASS HPFP 95. Have had it on for two years with no issues. I run 16PSI at idle 13PSI WOT with 32ft RV.
when you guys speak of pump pressure do you mean after the filter? cause i got a new stock carter pump on mine and i only got apx 6. 5 lbs at idle. filter is new also!
with my fass 150 pump only getting reading about 18" from injection pump 20 at idle and never below 15 at WOT.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-DD3600 TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " FTE 6" STACK D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 37" TOYO MT'S 6" RCD LONG ARM LIFT. :-laf... THANKS RIP DiPricol Gauges
