Tips:
Use the fuel line that comes with the kit, its good stuff.
When you to mount the pump bracket/hanger to the rear leaf spring perch, make a template out of cardboard of the three holes on the bracket/hanger. Use the template to mark the spring perch prior to drilling it.
Bypass the stock filter and plumb directly into the injector pump or you can buy the parts to plumb it directly into the old canister but really the stocker is no longer needed. If you choose to go directly into the pump be very careful to avoid getting any dirt in the pump.
Good luck, It's fairly easy, just take your time.
