I installed a new (carter) lift pump, she fired 2 X, ran for a few minutes then gagged and died! Could not get her to start after that so I had her towed to a local repair shop where they diagnosed 0 fuel pressure out of lift pump and recommended a FASS. I figured constant positive fuel pressure would be a good thing so I went for it.
Here were a few surprises I got.
When the service writer asked if I wanted the Prime Lock fuel filter relocation kit removed I assumed that he meant to completely bypass the CTD fuel/water separator since FASS already has a filter and a fuel/water separator. Instead they put the CTD back in its original location; you know the one that’s near impossible to reach. So now I have 3 filters total in my fuel system.
I asked the service writer if they would bypass the mechanical lift pump citing that I would make plate to replace pump and hold the Preheater/strainer in place. He said they would bypass the existing pump. In fact they went through the original pump, so now I have 2 pumps (one that produces 0 pressure on its own). Seems like just another place to develop a fuel leak.
I got enough black smoke to clear bugs out of city block so I turned starwheel all the way down and got back to something that would pass state inspection. Still have good pickup off the line.
The up side is that the truck runs strong. My impression is that the FASS is really overkill on a 12 valve. I would like to her some comments from others who have a FASS or not.
