RWatson said:Diesel Dan,
I believe I have a 150 with serial number 3616, kinda hard to read it upside down with a mirror. Will this program allow me to change to a 95gph? If yes to all the above, can you point me to a local dealer to get paper work? Do I need my original reciept... wife has probally buried it somewhere and would require an exploration team to find it. .
Junior said:Diesel_Dan I am registered for this. i have a 95 pump only with a 103 about serial #.
My question is what is the difference between the 95 and 150?
Is it just fuel pressure, that makes it flow more?
Also, would it benefit me any going to 150, 550 hp will be max. Most likely be in the area of high 4's and maybe low 5's. what oudl be the suggestions?
Also heard you guys have a larger fuel line from fuel canister to VP44. Could you pm or email details.
Junior said:Thanks for the info. Do i have to get the core back to you by the 1st of december, or do i have more time to get the core back to you guys?
If i confused you let me know
BRobertson said:I sent my core back months ago thru PDR, and I'm still waiting for a refund, and I'm only getting 10psi.
Bob
Junior said:Diesel Dan, hey doing the trade back trough Scott at Massdiesel.
Quest. After i had the pump initially i had low pressure. you guys sent out a higher pressure spring that is getting me around 15psi. what kind of pressure will the new pump have?
should i put a higher pressure spring in right away for the 500hp in future or just wait till i get to that point and see what happens with fp.
ctd8999 said:Diesel-Dan, This is off topic but I see you watch this post pretty close. So here is my question. I'm having a hard start issue due to a large amount of air in fuel. Is there anything in the FASS system that could have gone bad to cause all the air. Thanks Steve B.
ctd8999 said:Dan, I've checked all the suction side, removed the tank pick-up still looks like it did when I changed it. I'm doing my testing with hose right off FASS to tub of fuel. Pressure is 13# at idle close to where it always was. If I let the truck sit for 10 minutes I have to bleed a couple injection lines to restart. My problem could very well be the VP-44. But we have checked for codes and have none. I was not sure if there were any orings in the FASS system or not. Thanks Steve B.
Junior said:Just looked up price of new pump and it is only $60 more than what i will be charged which i find to be noo bargain at all with this motor campaign.![]()
$417 for pump only 95
RP-1002-HPFP (95 GPH HPFP) $195. 00 + $155. 00 Core (New SN# will be issued and new bracket is included in price of upgrade)
