Has anyone drilled and tapped for a mounting bracket on the opposite side of factory bracket? I'd like to mount the fass with some finger bushings to isolate the pump vibrations from the frame and it would be better if I could support it from both sides so there is more direct compression on the bushing and not a bit of shear due to the bracket being only on one side.
Hopefully someone has done this so I don' t have to guess the safe places to drill w/o hitting an internal passage!
Thanks!
Thanks!
